Initial Setup
Hi, I have a similar setup, on windows 7 PC with Audacity 2.0.2 - Have MME / Microsoft sound mapper -output/ Microsoft sound mapper - Input/ 2(stereo) Input channels.
Problem: While online recording any audio , I cannot see any waves while recording (no recording happens). What gives? Am totally baffled. And I thought i was good at Audacity!!! please help.
desperate - sim.
Split to new topic as this does not appear to be about recording from a USB turntable.
The current version of Audacity is 2.0.5. You can download it here: http://audacityteam.org/download/
Install the new version over the top of your old version and during the set-up select the “Reset Preferences” option. You will need to confirm resetting preferences on first run after upgrading.
If you’re wanting to record audio that is playing on your computer, try the WASAPI method described here: http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_windows.html
Hello Steve, Thanks for the update and yes, I upgraded it to 2.0.5 and I am good to go using the WASAPi method. I can record again, heyyy!! thnx so much really.
best - simsan
