increasing/decreasing selection [résolu]
i cannot select by small incremment .
only betwenn number
see picture attachement .
thanks
bonjour
je ne peux pas selection par petit incremment
mais seulement numero par numero
voir foto attachement
Remove the tick from “Snap To” in the Selection Toolbar (near the bottom of the main Audacity window.
http://manual.audacityteam.org/man/FAQ:Editing/fr#Pourquoi_ne_puis-je_pas_s.C3.A9lectionner_moins_d.27une_seconde_ou_cliquer_entre_des_secondes_enti.C3.A8res_.3F
thanks for your time
yes i was expecting the selction bar with number
but in this version 2.0.1
i do not find the selection bare , at the bottom or anywhere else
a picture of my screen is in attachement .
mac 10.6.8
bonjour
je ne trouve pas la barre de selection
voici un png de mon ecran !!!
hello
problem resolved found it was not in view
bonjour
problems resolus
la fenetre n’etaait pas visible
merci pour votre temps
