Imposible to record.
Hi,
Audacity 2.3.3
System : Windows 10 family version 10.0.18363
I want to record music from YouTube or from On Line Radio, but when I click on the record button, nothing happens : the time line bar under the right red marker doesn’t move :
The samething happens if I try to record from an audio file already on my hard disk.
The samething happens if I change the input option (e.g. “Realtek high definition” instead of “Stereo Mix”)
Here is the log file (from the help section) :
11:59:42: Audacity 2.3.3
11:59:42: Erreur : Impossible de trouver le symbole « AudacityModule » dans la bibliothèque dynamique (erreur 127 : La procédure spécifiée est introuvable.)
11:59:44: Trying to load FFmpeg libraries…
11:59:44: mLibAVFormatPath (‘C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll’) is not empty. Loading from it.
11:59:44: Looking up PATH environment variable…
11:59:44: PATH = ‘C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Java\bin\java;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files (x86)\FFmpeg for Audacity;C:\Users\H\AppData\Local\Microsoft\WindowsApps;C:\Java\bin\java;’
11:59:44: Checking that ‘C:\Program Files (x86)\FFmpeg for Audacity’ is in PATH…
11:59:44: FFmpeg directory is in PATH.
11:59:44: Checking for monolithic avformat from ‘C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll’.
11:59:44: Erreur : Impossible de trouver le symbole « avutil_version » dans la bibliothèque dynamique (erreur 127 : La procédure spécifiée est introuvable.)
11:59:44: Erreur : Impossible de trouver le symbole « avcodec_version » dans la bibliothèque dynamique (erreur 127 : La procédure spécifiée est introuvable.)
11:59:44: avformat not monolithic
11:59:44: Loading avutil from ‘avutil-52.dll’.
11:59:44: Loading avcodec from ‘avcodec-55.dll’.
11:59:44: Loading avformat from ‘C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll’.
11:59:44: Actual avutil path C:\Program Files (x86)\FFmpeg for Audacity\avutil-52.dll
11:59:44: Actual avcodec path C:\Program Files (x86)\FFmpeg for Audacity\avcodec-55.dll
11:59:44: Actual avformat path C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll
11:59:44: Importing symbols…
11:59:44: All symbols loaded successfully. Initializing the library.
11:59:44: Retrieving FFmpeg library version numbers:
11:59:44: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
11:59:44: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
11:59:44: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
11:59:44: FFmpeg libraries loaded successfully.
I have desinstalled and reinstalled the FFMPEG library, the LAME library, and Audacity 2.3.3, but it doesn’t change anything.
I can read audiofiles without any problem.
Thanks for any help !
Try setting “host” to “MME” and the recording device to “Stereo Mix” in the “Device Toolbar” (https://manual.audacityteam.org/man/device_toolbar.html)
