Importing vinyls to itunes
Is there a way to import vinyls to iTunes?
I don’t think I would use those words.
You can play each vinyl record and record it on your computer with Audacity. After you do that, you can break up each record into individual songs and export as many sound files as that process gives you.
Then, you can drag or copy the exported files into iTunes — or any other music program.
People usually figure out right away what a time-consuming pain that is and find reasons to buy the music as downloads or Audio CDs.
See http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html and http://manual.audacityteam.org/o/man/sample_workflow_for_exporting_to_itunes.html .
