importing .mp3 file
when I try to import file .mp3 ( my file is about 30 min ) I have this message :
import failed
this is likely caused by a malformed MP3.
Do you please any help? :confused:
Audacity is more picky about MP3s than most applications but it also depends on the Audacity version so if you arenโ€™t running the latest version (currently 3.0.5) try upgrading first.
Or see [u]this topic[/u] which has a couple of work-arounds.
