I’m importing a set of MP3 files to build a single mixed MP3 file. Some of the files import and some do not. There does not seem to be any rhyme or reason.
Audacity did not recognize the type of file
<filename>
Try installing FFmpeg.
FWIW ffmpeg is installed. I know the files on which Audacity balked are good .mp3 files. I’ve never seen this error before.
I use home brew, and coincidentally, brew upgrade installed a new version of audacity yesterday. It had been awhile since I used audacity so I can’t say which prior version was the first to have this error.
Should I fall back on an earlier audacity? Should I not use brew to install Audacity upgrades? This has not been a problem before.
Other apps do not have trouble with the files. On a lark I used the file command against the .mp3 and got this –
40-sophie_zelmani-to_know_you.mp3: Audio file with ID3 version 2.3.0
which looks ok to me but other files show more details –
29-folk_implosion-gravity_decides.mp3: Audio file with ID3 version 2.3.0, contains:MPEG ADTS, layer III, v1, 192 kbps, 44.1 kHz, Stereo
It’s notable that the ones Audacity does not like have the additional layer, rate, kHz, and stereo information missing. It must be in how those .mp3’s were originally written.
I haven’t been able to look at this for awhile, but tonight I had some time to explore it again.
The problem is not stripping the extra layers. Those files (with the extra layers) are fine and Audacity is ok with them. It’s the files that do not have the layers.
They open fine in VLC (and when copied to my Android), but opening them and saving them back is a heavy time-consuming process and I’m finding more and more files with this problem, thus rendering this solution sub-optimal.
This has to be a problem with a recent version Audacity. I’ve never had problems with it opening any .mp3 before.
I don’t understand what this means. What are the additional layers that are added and where did they come from? The .mp3 files in question were produced by Total Recorder in a process similar to each other. It’s not like I consciously chose some files to have the layers and some not.
Maybe this is on ffmpeg? I could look there and see if there is a conversion argument that will strip, add, or reorder the layers in an agreeable manner.
Converting them all to .flac fixes the problem. I can work around that but I still believe there is an error somewhere in Audacity and/or ffmpeg that won’t process the .mp3 files.
Thanks for your reply Steve, Maybe I was fat-fingering my statements earlier. To clarify, the info I got on the files came from the Unix-level ‘file’ command. If the file output showed
Audacity would not recognize it or import it. But if it showed
Audio file with ID3 version 2.3.0, contains:MPEG ADTS, layer III, v1, 128 kbps, 44.1 kHz, JntStereo
then it was imported. I’m just going to use ffmpeg to convert to .flac and call it a day.
If you are interested in finding out what’s different between the “good” files and the “bad”, you could try analyzing them with https://mediaarea.net/MediaInfoOnline and look for common factors and differences.
