Probably missing something but the load preset button is greyed out to install an XML EQ file. Doesn’t matter if I have audio in the project or not.
Any ideas?
Any ideas?
It’s grayed out because it’s not available in 2.3.3
Import of EQ curves will be available im 2.4.0
the files will need to be in TXT format
2.4.0 will have a tool for XML curves to TXT curves conversion
currently 2.4.0 is scheduled for 7th May
Ok thanks buddy
