iMic device
Can I still use an iMic device to connect Walkman to 2.1.2 Audacity
You should fill in a few more of the holes. You didn’t tell us which operating system you have or which kind of computer. You should also tell us what the numbered version of Audacity you have.
Assuming you are still on Windows I moved this topic there. This is nothing to do with compiling Audacity.
Yes you can use an iMic to connect a Walkman to the computer. Set the iMic switch to “Line”.
