Im needing some help
hello im a new content creator and im trying to clean up my audio but i cant get this static sound the be removed, i have looked through the filters but i cant seem to find the right one. any help would be apricated
That’s really damaged. How are you recording that? Microphone? Interface? I don’t think you’re going to get to good audio with effects and filters. Your recording system is broken.
im using a blue snowball i never had this issue before, ill take a look at my cords to see if something is messed up.
Sounds like Windows-audio-enhancement processing, which should be turned off …
(in both the recording & playback tabs)
Thank you I will try this.
I used a Snowball for a while and it didn’t sound anything like that.
