im doing an lp for a friend with audacity…im having a problem finding the high point in the song with audicity…either the orchestra is too loud or the vocalist is and it seems
to occur thoughout the song so its very hard to find the high points in the song…it happens thoughout the song.im using a dell 1100 desktop on firefox browser…anything
i can do?thanks
"by doing "i mean recording an lp…by high point i mean where the wave reach the top of the top of the wave editor…and yes im trying to set the recording level…
Hi Lenny, I understand now.
Are you using a USB turntable? or a normal one connected to the sound card input? or a normal turntable connected to the computer through a USB pre-amp? or something else?
Are you able to adjust the recording level at all?
im using a usb turntable to an exterior soundcard…im using a preamp from my turntable then into my computer…im not using a regular reciever anymore…yep i can adjust
the sound as its going into my cumputer from my sound card…
Set Audacity to record at 32 bit (Edit > Preferences > Quality)
Then record the whole thing a bit “too quiet” (set the recording level lower to allow more “headroom” for those loud bits).
You can record at a fairly low level, then use the Amplify effect after you have finished recording to bring the level up to maximum.
As long as you don’t go too extreme the sound quality will not suffer.
