I recently changed from 3.2.1 to 3.7.9 and the colors are not very good
I recently changed from 3.2.1 to 3.7.9 and the colors are not very good. The choice of 4 different colors for waveforms is a great idea but none are good for me. Normally an orange or amber color for the waveforms on a dark theme works best. I worked on the very first pc’s when they didn’t even have rgb so I know they did studies about it and chose amber.
Here’s a search report from google: (Note: with AI enabled - to disable AI: add “-AI” without quotes after search string)
Both amber and orange hues feature longer wavelengths that produce less eye fatigue than short-wavelength blue light, but an amber or warm yellow-orange tint used as an overall background or screen color temperature—rather than bright orange text—is generally best for reducing strain. [1, 2]
Amber vs. Orange for Eye Comfort
  • Wavelengths: Orange and amber fall on the longer end of the visible light spectrum, meaning they carry less energy and cause less acute retinal fatigue than harsh blue light. [1, 2]
  • Contrast and Legibility: For actual text readability, the highest visual comfort and lowest strain come from high contrast combinations—traditionally sharp dark text (like black) on a light, warm-tinted or slightly amber/yellowish background, rather than colored text floating on a dark screen. [1, 2, 3]
  • Time of Day: Using a warm amber or orange-red color filter (such as Night Shift or f.lux) is particularly effective in dim environments or during evening hours to minimize blue light exposure and protect your natural sleep cycle. [1, 2]
And yet blue light blocking glasses make no difference … Blue-light filtering spectacle lenses for visual performance, macular (back part of the eye) protection, and improving sleep quality | Cochrane
[ Google/AI does not have a BS detector : they will regurgitate product promotion ].
Try it yourself. If you want very bright backgrounds don’t worry. If you want high contrast don’t worry. If you want something in between then add the option of more waveform colors.
Ps. I never have used blue light blocking glasses.
Source and Spectrum Shape
  • Sunlight: Natural blue light is part of a balanced spectrum that includes all other colors of visible light, plus infrared and ultraviolet rays.
  • TV Screen: Most flat-screen TVs use LED backlighting that creates a sharp, concentrated spike in the blue light spectrum (usually around 435–440 nanometers) alongside mixed red and green light to form a white image. [1, 2, 3]
How They Affect You
  • Circadian Rhythm: Both sources tell your brain that it is daytime by suppressing melatonin production. However, viewing a bright TV screen at night tricks your internal clock, delaying sleep and making it harder to fall asleep. Sunlight during the day helps keep your circadian rhythm healthy.
  • Eye Strain: Blue light from a TV does not physically damage or burn your retina during normal use. Instead, looking closely at a digital screen for hours reduces how often you blink, which causes dry eyes, fatigue, and headaches (known as digital eye strain). [1, 2, 3, 4, 5, 6]
Keeps you awake/stimulated when you should have gone to bed. That the blue light blocking glasses make no difference to sleep quantity/quality means blueness is irrelevant.
Custom colour themes were possible for Audacity 3 … Audacity 3 themes - Audacity Forum
