I observe/mesure exactly a different latency (typically 200-400 ms) , from time to time , when doing many recordings (wh
I already published that in another topic, no real explanation or solution, and was said better to start a new one
Here it is !
XavierRodet
Re: Recording new track to saved project in sync, when playback new track is out of time but in time by itself seperatel
Post by XavierRodet » Thu Jan 28, 2021 6:14 pm
MacOS Big Sur V 11.1 5(0C69) SSD hard Disk Audacity 2.3.3 Great Software !!!
I am new ( Thursday Jan. 28 2021 ) on the Forum. At the moment I cannnt find the proper answer, thank yu in advance
Input & output through USB → Diamon Sound Tube (a simple sound “card”)
I observe/mesure exactly a different latency (typically 200-400 ms) , from time to time , when doing many recordings (while playing sumultaneously for play along/playback usage)
though WITHOUT change :
no change of hardware
no restart of Audacity
no change of Sample Rate
what else ?
The only (I believe) things I change are:
  • the zoom in the window where I play and record simultaneously for play along or playback usage
  • a New Window for the play along and recording tracks
  • Put the Mac to sleep (a correct translation for the French “Suspendre l’activité d’un Mac” ? … acording to gogol…)
Of course, after measuring it , I can compensate exactly (I use click tracks) but it is annoying and time consuming.
Even if no solution, I would be happy to know WHEN / HOW it occurs ???
Any hint ???
Thank you in advance !
Xavier Rodet
Top
The latency is likely to change if there are any changes to the sound system, such as changing the device, changing the sample rate, changing the bit format. I don’t know why the latency would change if there are no changes to the sound system - that doesn’t happen for me.
