I Need to Fix a Segment of Poorly Recorded Audio
I;m using Audacity 2.0.5. Many parts of some audio I recorded have segments of sound that are really warped and at completely different levels.
I have a link to the screenshot here, and I have the audio clip of it attached.
I’d like to know if there’s a way to make this better, or if it’s just too badly recorded to bother.
I apologize for not being specific enough, but I don’t know exactly what I need to do.
I can get rid of a lot of the distortion through clever tricks, but the portion right at the end is hopeless because there’s no show there to rescue (attached).
That actually sounds decent. How would I go about replicating it?
Moderator note: please do not triple post, I removed the duplicates for you. Unfortunately we have had to introduce post moderation for new Forum users to avoid being deluged in a flood of spam, mostly advertising but some very unpleasant and some downright dangerous. We do have moderators scattered around the timezones of the world so it doesn’t normally take long for your post to be moderated and displayed. We try to keep this little corner of cyberspace a sane and family-friendly place to visit.
Somehow you managed to have your show ping-pong between left and right several times. Since the show sound never really dropped out, I reduced the show to mono and those effects vanished.
Tracks > Stereo Track to Mono.
Then, since most of the trash is rumble and truck-driving-by sounds, I filtered them out with Effect > High Pass Filter: 150Hz, 24dB.
Many field pro sound mixers have a button so you can apply that filter during the recording, so I’m not making that up. The default cutoff is 100Hz, but I have a mixer with 80Hz and 160Hz selectable with a switch. Try different numbers. You’re juggling suppressing the thumping pops versus the low, velvety quality of your voice. As the number goes up, your voice tightens up.
