I need the change the scale of karaoke music
Hi,
I need the change the scale of karaoke music from C# to B. How do I go about it? I am new in this forum and would not follow the technical jargons. Can you kindly let me me know the procedure/steps to follow in simle language? Also occasionally I may want to reduce the speed also. Shall be grateful for the suggestions.
Thanks.
-BasuThakur-
Please do not piggy-back on existing threads which bear no real relation to your problem - always much better to start a new thread. I spun it off for you and gave it a sensible title.
Try using Effect > Change Pitch
See this page in the Manual: http://manual.audacityteam.org/o/man/change_pitch.html
