i need help
i want to press my keybind to record when im in a game but the keybind wont start recording unless im in that tab please help
Audacity usually comes out on the bottom if there’s conflict with keyboard mapping. The solution may be start Audacity recording first and then edit out all the extra time after you’re done. You might also find you can’t capture game sound and your voice at the same time. Capture the game in Audacity, wear headphones, and capture your voice with your smartphone. Combine the sound files in editing.
I know it’s tempting to perform once, press stop and go to lunch, but it mostly doesn’t work like that. Good shows are made in editing and as a fuzzy rule, editing takes five times the length of the performance if you’re good at it.
I won’t sit through a demonstration video where the performer makes a mistake and then makes me sit through correcting it. Edit those puppies out before you publish.
