Hello, first time poster here. I need to lower the dB for an .xwb file but when I open it up and lower the volume I can’t save it. There’s no way to save changes without exporting as something else.
So my question is, is there a way to save to the file instead of exporting? Thanks in advance. I’m using version 2.1.2
A solution that definitely works is to use the command-line XWBTool to convert a WAV file or files to XWB but as far as I can tell you have to compile this using Visual Studio.
We can’t help you with this. You “may” still be able to find a ready-compiled XWBTool on a gaming forum but most such links to it have been removed due to copyright concerns.
