I need help bad yall. Recovering a 9hr audio file
Okay, I have done the command line.Prompts with the recovery tools and have created the broken recovered file and the broken file.But the one , the only one that has worked so far was the recovered , and it’s over , I says the stereo channel is missing.I haven’t been able to get anything else to work or to get any farther.And I really, really need this.Please someone help. Using the latest version of audacity
9 hour audio file, or 9-Hour Audacity Project? Are you doing all this work on the machine’s internal drive, or an external, remote, or network drive?
What’s the show? Have you produced one like this before?
A nine hour stereo WAV file comes in about 5.7GB which I believe exceeds the WAV format abilities. If this is a perfect quality Audacity Project, it’s going to be far larger than that.
Do you have backups or copies of all the material you used to make this show? That brings us back to what is this show?
Thank you for the response! I actually meant to come back and put this as fixed yesterday and forgot. It’s a 18ish gb file tho and it was processed internally but stored on a external 1tb drive. I ended up being able to find a previous state to return the file to and then I was able to save it and then chop it into 2hr chunks so that the program could handle it lol ty tho
Thanks for posting back. We get our library of advice by posters telling us their successes.
