I just downloaded a new version of Audacity, but when I select the Wasap host my recording has high static, when I select MME, no recording devices are listed, so when I record, I get “error opening recording device Error code : 0 success”.
What are you trying to record from?
If you are trying to record streaming audio turn-off Audible Input Monitoring. It creates an internal feedback loop when you are trying to record what you’re hearing and then hearing what you’ve just recorded and recording it again…
And check your Check your Windows Permissions/Privacy Settings to make sure Audacity can access your microphone (or whatever).
