I cant not find the vocal remover effect [SOLVED]
Hey guys. I just downloaded audacity a couple of days ago because I wanted to mess around with the vocal remover effect but it’s not there. I pull down the effects menu and it is no where to be found. Did I do something wrong? I am running 10.10.1 Yosemite. thanks
It’s down at the bottom (attached). The effects on Macs are in two segments.
Does your Audacity > About say version 2.1.0?
Hey thank you so much for the fast reply. I ended up reinstalling it and found it. I’m still not sure what was wrong. maybe somehow Audacity wasn’t up to date? I don’t know. Thanks again for helping.
