3.6.4
Pause + record i cant hear the sound but it is coming thru fine.
I can listen to the recording that was made.
I really scratch my brains how to set this.
UFO202. Got the stero sorted out.
Windows 10 Toshiba Tecra C50-E
Input - USB audio codec
Speakers - Microsoft Sound Mapper or Speakers Reaktek
Using laptops headphones as monior.
First time i’ve used this version
Check your Playback Device device options. There may be a separate selection for headphones or speakers. You can also plug your headphones into the UFO202 and select the UFO for playback & monitoring.
Also check the playback volume slider which is now “hidden” behind the playback meters. (But if you can play back with Audacity, that’s not the problem.)
