Hi,
I’m new!
I bought the device from Aldi in October of 2011. I never even got to open the packaging as we had a family bereavement the very same day so nothing ever got done.
I have just picked the box up and looked at the contents. I have followed the instructions enclosed and I have printed the user guide that was included on the disc that came with it.
I installed the software and plugged the cassette converter into my USB and that seems to have installed OK too.
I tried to follow the preferences, although I didn’t see the same thing under Recording Device (I don’t see and can’t select USB Audio Device).
I inserted a tape and pressed Play, but I don’t see any movement on the screen. I should see the Input Level meter moving side to side but I can’t see anything moving. I stopped the tape after a couple of minutes.
I am running in Windows 7 (64-bit Home Edition).
The version of Audacity on the disc I think maybe 1.2. which I can see is no longer valid. I updated the version to the current version from this web site.
I tried running the tape again but I’m still not getting anything.
This seems very complicated - all I really want to do is transfer some music I have on some old tapes to CD. I am not very technically minded regarding this sort of thing and I am feeling quite lost.
Is there anyone who can get me going on the right course?
Please keep it as simple as you possibly can.
So looking for support, I finally ended up here
I set the tape going and
