I CAN'T FIND THE _DATA FOLDER!
I’ve looked everywhere and I can’t find the data folder for my saved projects. I usually work with Audacity of my PC, but I’ve since moved to a Macbook (High Sierra). I’ve checked the Trash Bin and can’t find it anywhere. When I open the project from my finder it opens just fine, but I’m sending it to someone so I know I need the “_data” folder.
Thanks!
Current versions of Audacity don’t have a “_data” folder.
The Audacity project format changed with Audacity 3.0.0 (the current version is 3.1.3).
Old 2.x projects:
“AUP” project file + “_data” folder.
New 3.x projects:
Self contained “AUP3” project file.
