I recorded 3 files this morning, on two computers, both on above OS and Audacity cannot locate them.
I went into Start into the Audacity icon and it showed two files I recorded on my laptop, one had 0 bytes and the other one had 317 KB. But neither one can be found.
I searched my download folder and documents, not there!
I also have the Aud folder on my desktop but nothing is inside.
Anyone have any idea where this could be? I am a new user to Audacity. Thanks!
There are no “Aud” folders produced by Audacity, so again I suggest you make sure you have obtained Audacity from us.
If you used File > Save Project…, click File > Recent Files which should open the saved AUP file.
If you used File > Export…, open that menu item again. It should open to the location you exported to.
Audacity Projects (AUP file and _data folder) are only for Audacity. No other applications on your computer can open Audacity Projects. Please see here for an explanation of what Audacity Projects are: http://manual.audacityteam.org/o/man/audacity_projects.html .
