I can not turn on Equalaizer.
I can not turn on Equalaizer in Audacity. What can I do?
The old Effect > Equalizer has been split into two different Effects: Filter Curve and Graphic Eq. If you liked using the old drawing curves system, then Filter Curve is for you. The old standard installed curves are available under Manage > Factory Presets. That’s where Low Rolloff for Speech is if you’re performing audiobooks.
And to make things clearer “Does what it says on the Tin”
For the next release 2.4.0 we have changed Filter Curve… to be Filter Curve EQ…
Just so that folks realize that it is an EQ Equalizer effect.
Peter.
