I backed up audio to the cloud option. When I attempted to retrieve I got an error about block files
“timestamp”: 1713962282,
“event_id”: “37e4f0eb44871d4aa2bf1ad80b9de81e”,
“platform”: “native”,
“release”: “audacity@3.5.0”,
“contexts”: {
“os”: {
“type”: “os”,
“name”: “Windows”,
“version”: “10.0.22631”
“exception”: {
“values”: [
“type”: “Error_Opening_Project”,
“value”: “Project is corrupt\n(Unable to work with the blockfiles)”,
“mechanism”: {
“type”: “runtime_error”,
“handled”: false,
“data”: {
“sqlite3.query”: “DELETE FROM sampleblocks WHERE NOT inset(blockid);”,
“sqlite3.rc”: “11”,
“sqlite3.context”: “ProjectGileIO::GetBlob”,
“log”: “08:38:02: SQLite error (283): recovered 17905 frames from WAL file Betrayed 21, 22, -wal\n08:38:02: Loaded 75 string Kb in size\n08:38:02: SQLite error (11): database corruption at line 66843 of [1b256d97b5]\n08:38:02: SQLite error (11): database corruption at line 66993 of [1b256d97b5]\n08:38:02: SQLite error (11): statement aborts at 3: [DELETE FROM sampleblocks WHERE NOT inset(blockid);] database disk image is malformed\n08:38:02: DBConnection SetDBError\n\tErrorCode: 11\n\tLastError: Project is corrupt\n(Unable to work with the blockfiles)\n\tLibraryError: database disk image is malformed\n”
Heya! You may want to try to clear your cache. The cache is located in %appdata%\audacity\CloudProjects and all files inside it are safe to delete. (If you want to be extra safe, you can just move the files inside to a different folder, such as the Download folder)
Next time you start audacity and open the project, it should download the project from the cloud again, which should fix that issue.
