Hello,
I am using Audacity 3.7.3 to cut a song for a dance competition.
I had to remove 30 sec from the song, at the middle but I still have a cut between the 2 pieces I put back together.
I tried fade in, fade out but not better.
I tried to zoom to cut more precisely without success
Does someone has a magic trick to share?
Thank you!
Try to match the beats and you can make a very-short crossfade of a few milliseconds, or longer like a second or more for whatever sounds best. Iād probably start with about 1/4 second (or about the time for one beat). It will probably take some trial-and-error.
You may want to start by making two files for the 1st & 2nd part (with some extra where they will overlap). āImportā (donāt āopenā) the 2nd file and drag it to the right.
Thank you DVDdoug!
This is what drives me crazy, bcz i inserted a āsilenceā between the 2 pieces, added fade out āautomatedā and by hand (by decreasing the volume? not sure itās validated the music editing church :D).
Iāll try the overlap option right away!
yuhu! I managed! thx!
