how do I split the hyper crispness from the normal, clear speech?
It’s usually better to avoid problems rather than trying to fix them later.
How are you recording your voice?
What microphone do you have (make and model)
How is the mic connected to your computer?
What sort of mic stand do you use?
Where is the mic positioned relative to your mouth?
Are you using a pop shield?
How are you listening to the recording? (please include make / model of the headphones / speakers that you are using)
Please include a short (say around 6 seconds) recording in WAV format to illustrate the problem.
