Hello,
I am new to Audacity, and would appreciate suggestions on how to use it [or recommendations for something else] to record phone calls on a Win11 PC. By record phone calls, I mean to be able to record both sides of the conversation while it is ongoing.
The phone line I want to record is a VoIP line from a Grandstream HT814 v2 adapter with a RJ45 Ethernet port connection to a router and a RJ11 phone line port to a Uniden cordless handset.
A tech at TVPS.com recommended the following telephone recording adapter and said it should work with any PC audio recording software:
The User Guide says to plug existing phone line into the DUPR, plug the DUPR phone line into the phone handset, and plug the 3.5mm DUPR cord into the PC’s microphone jack.
Suggestions and comments would be appreciated on (i) whether the DUPR with Audacity will allow both sides of the conversation to be recorded with that setup, and (ii) any tips on using it (or any suggested alternative hardware or software) for 2-sided ongoing phone call recording.
Thanks.
