How to use doCommand?
do_command(‘PlotSpectrum’)
do_command(‘Export2:Filename=“{123.WAV}”’)
Export the “PlotSpectrum” file; the “Command” has no effect.
I assume that you mean do_command() from pipe_test.py.
In which case, do_command must be called from the Python script, and must pass a valid scripting command. You will need to know a bit about how to program in Python in order to use it effectively.
