It is audio line in on a Dell PC. My choices are “default”, “pulse” or “HDA Intel PCH: ALC3220 Analog (hw: 1,0)”. My only choice for audio host is ALSA.
I just tried specifying HDA Intel but when I try to record most of the time it doesn’t start.
I did notice that when I went to change the volume on KDE mixer that the recording stopped.
To fill in more standard information, I installed Ubuntu’s version of Audacity.
Your default device is the HDMI device. Do you use HDMI audio? Do you use HDMI audio as your default audio out?
I don’t use HDMI audio. The only connection is the analog line out (on of the back the PC) out to speakers and analog mic in (on the front of the PC).
My monitor connection is currently VGA but otherwise I use DisplayPort (which I think is video only).
Have you customised your audio system in some way?
I was just checking that you hadn’t deliberately created a custom configuration for your audio devices. Clearly you haven’t
I’m not sure exactly what is going on with your setup, but compare this (below). This is my laptop’s setting, which is a default configuration in Xubuntu 18.04 LTS.
Notice that it shows that I have similar hardware, but that on my machine the default device is:
card 0: PCH [HDA Intel PCH], device 0: ALC269VC Analog [ALC269VC Analog]
The key word is “Analog”. That’s the normal audio in/out of the laptop and it is the default device.
HDMI audio is connected to the laptop’s HDMI port, which is only used if I connect a second monitor that has built-in speakers.
I don’t know why your default device is not the analog audio in / out, but the fact that it isn’t looks wrong to me.
I found this post via a Google search: https://bbs.archlinux.org/viewtopic.php?id=182023
I don’t know if their steps to fix the issue will be appropriate for your machine, so don’t blindly follow those steps. I’m just mentioning as there are some clear similarities:
Their default card appeared to be set as HDMI.
Their system appeared to work correctly for a few minutes and then stopped.
The problem appears to have been fixed by changing the default device from HDMI to the analog device.
Unfortunately I don’t know enough about the sound system on KDE to guide you through this. I’d suggest that you see what you can find out about this via Google, and perhaps try asking on the Ubuntu forum.
