how to split file
I am using XP sp3. How can I split a wav file equally, then export the
two files? Thanks, Glen
I don’t know what you mean by “the exact three-section version of Audacity”
Look at Help > About Audacity… and you will see three numbers, such as 2.1.3. What does your copy say?
Click in the waveform at half way, and Ctrl + B to add a label. For more accuracy, try Analyze > Regular Interval Labels… . First box, choose number of labels. Second box, choose “2” labels.
File > Export Multiple… . Put a tick (checkmark) in “include audio before first label”. Choose the export format and location at the top.
It’s 2.1.3 Thanks. Glen
If you want an exact “first half / second half” split, then probably the simplest way is to use the Selection Toolbar (http://manual.audacityteam.org/man/selection_toolbar.html) to select exactly the first half of the track, and export using “File menu > Export Selected Audio”, then select the second half and export in the same manner.
If you don’t need the selection to be exact, then you can just “Zoom to fit” (http://manual.audacityteam.org/man/edit_toolbar.html#zoomproject) and select one half at a time using your mouse. See here for more information about making audio selections: http://manual.audacityteam.org/man/audacity_selection.html
