How to select many clips?
Hello Team,
I split audio to 5 small clips, how to select two clips of them? The ‘Shift’ and ‘Ctrl’ key didn’t work in this task. We have ‘Ctrl+A’ to select all clips but we don’t have function hold Ctrl key and select multi-clips we want.
Thanks!
If the two clips are adjacent (no clips between them), you can click and drag across the clips. Zoom out if necessary so that you can see them both.
Audacity does not currently support multiple selections selections at the same time, but if you have a track containing 3 clips and you want to process the outer two without processing the one in the middle, you can move the middle clip to another track.
Author should update multi-select and random select clips by ‘Shift’ and ‘Ctrl’ key.
