Hi,
Is there a way to select a zone of the waveform, press play, and when the cursor reach the end of the selection, restart from the beginning of the selection?
Dont want to make looping points etc, just Quick selection and loop the playing.
Is it possible?
What do you see when you make a selection and then right click on it?
I can’t run Audacity right now, and the manual website is down, so I can’t verify anything.
I’ve resolved with the icon of Loop in the toolnbar, thanks!
