How to save chain file to transfer another computer
Hello!
I am building a PC and have my audacity all setup with chains etc for my audio. How do I transfer those chains to another CPU? Where do I find the files?
If I recall correctly, by default, Chains were in the hidden folder:
C:\Users<your user name>\AppData\Roaming\audacity\Chains\
In Audacity 2.3.2, “Chains” have been renamed as “Macros”, and the available commands have been considerably extended.
By default Macros are in the hidden folder:
C:\Users<your user name>\AppData\Roaming\audacity\Macros\
You may find some incompatibilities between some old Chains and the current version of Audacity, so check that your Chains work before using them on a big batch conversion job, and update the Macro if necessary.
