How to review work
Hello,
I made a multi-track track with a different tone frequency per track. Example 200 hz. How do I go back and review each track to make sure I input the right frequency?
Could select a single track, then plot spectrum
If you used sine wave there should only be a single peak.
[If you select all the sine tone tracks in your project all the peaks will be shown on the frequency analysis plot].
