How to remove fixed durations at beginning and end of hundreds of files?
Hi.
I am a new comer to Audacity. I have hundreds of audio files that I need to remove fix durations at the beginning and end of each file. There are many macro commands so I am not sure which ones should I use. Any help is appreciated.
What kinds of files are they? MP3? WAV? This job may be more difficult than just cutting the beginning and ending off.
  • SelectTime:
  • Delete:
  • ExportWav: or ExportMp3: or ExportOgg:
Details of each can be found here: https://manual.audacityteam.org/man/scripting_reference.html
Worked, thank you!
