How to remove a phone call sound from the recording?
Hello!
I have a recording with two phone call sounds and I need to cut them out. Which tool should I use for this?
I can record a clean phone call sound in the same equipment if it is necessary.
Select the first sound to be deleted (http://manual.audacityteam.org/o/man/audacity_selection.html#mouse)
Then: “Edit menu > Remove Audio or Labels > Delete”
Repeat the above two steps for the second sound.
See here for further help with basic editing: http://manual.audacityteam.org/o/man/tutorial_editing_an_existing_file.html
