Hello,
I just installed Audacity. I just want to record my voice. But I don’t find where/how to do this simple record
Thanks for your help
Hello,
To start with, you’ll need a microphone.
Tell us what equipment you have, and we’ll help you out. Give us as much detail as possible.
Thanks a lot,
I was able to do my first record , but the quality of the sound is not very good. My microphone is a small one (Logitech “Skype compatible”). The sound with Skype is usually excellent. But in Audacity, there are a lot of “bloom bloom” loud noises. How can I get rid of these noises which are using all the bandwidth.
Thanks again
