I am using windows 7 and audacity application 2.1.1
Can you please advise how can i record the sound in headset and my voice via microphone simultaneously. It seems my sound card does not support stero mix.
Please adivse how this can be achieved. I have tried the the recording listen tab and by clicking listen to this device but there is lot of eco and does not fit my requirement.
Any suggestion/help would be greatly appreciated.
If you’re on Windows, you might try VoiceMeeter.
http://vb-audio.pagesperso-orange.fr/Voicemeeter/
Bear in mind you won’t be able to edit your voice and the song separately unless VoiceMeeter has a way of putting them in separate tracks.
A better method is to import the music into Audacity then record from the mic input.
