How to record the output of the headset?
Audacity 2.2.2
I want to record the headesetoutput but I get this error:
https://i.imgur.com/EB6EruM.png
I use the following settings:
https://i.imgur.com/248b1Zr.png
Basically I want to record the soundoutput of skype/teamspeak/discord and others… I can switch to english if you tell me how do it.
Please tell us what the error message says (in English).
Maybe not. That will only give you the sound from the rest of the conference and not you. Most people want to record both sides. That’s the hard one.
Same as here I guess: https://helpdesk.birdvilleschools.net/hc/en-us/articles/115006045848-Audacity-error-while-opening-sound-device
https://manual.audacityteam.org/man/faq_errors.html#sound_device
I already read this faq. It only isted a few possible cases but doesn’t give me a solution to my problem.
9996 Invalid device: this means that the sound device is not valid, if it is an external sound device:
it may have been unplugged
you may have a faulty or loose connection
you may have a bad lead
the device itself may be faulty.
Im using a wireless headset but even with the cable plugged in it gives me the error. The device/headset is working without problems.
