how to record streamed sound, eg from You-tube [SOLVED]
re: Audacity 2.1.2 from exe installer, Windows 10
A recent “upgrade” to Windows 10 appears to have abolished my ability to use another program (the aging AudioRoom Recorder*) to record “What U Hear” - in other words, anything I can hear on my computer speakers. This has been very useful, eg in recording the sound from a You-tube video. I tried “Audio Recorder for Free” but cannot get that to work either - maybe for the same reason. Someone recommended that I used Audacity (a previous version of which I had), but after I uninstalled it, and installed Audacity 2.1.2, LAME and FFmpeg, as well as the plug-in package. I cannot see how Audacity could perform this task. Another post on this subject advises that “Audacity does not download anything from the internet. …use your video downloader to download the video. Drag the video into Audacity and it will extract the audio without quality loss.” However, I don’t know what they mean by “video downloader” - so that would be Question 1.
Trying to follow the advice elsewhere on this post, i cannot find the “Device Toolbar” referred to. So Question 2 is, how do find Device Toolbar? That advice was:
try doing this in Audacity 2.1.0 from http://audacityteam.org/download/windows.
Open Device Toolbar .
  1. In the first (Host) box of Device Toolbar, choose “Windows WASAPI”.
  2. In the second (Recording Device) box in Device Toolbar, choose the (loopback) input for the device that is playing back the audio - so presumably SoundBlaster.
  3. In the third (Recording Channels) box in Device Toolbar, choose mono or stereo.
  4. In the fourth (Playback Device) box in Device Toolbar, choose the Speakers or Headphones that you are using for listening. It will be easiest to choose SoundBlaster, assuming your Logitech speakers can plug into SoundBlaster.
  5. Start playing the audio you want to record.
  6. Press the big red Record button in Audacity.
    It’s not clear whether “Device Toolbar” is supposed to be in Audacity [my version is 2.1.2, not 2.1.0], or in the download website page somewhere - either way, I cannot find it, so cannot get to Step 1. Further explanation or advice would be appreciated.
    My aim is to be able to record “What U Hear” simply and straightforwardly, in a format(s) that I can use in Audacity and Amazing Slow Downer. So I may be asking the wrong questions to generate the answer I need.
    *PS AudioRoom Recorder, an excellent program that is now 11 years old and legacy software, actually will not work now- it gives an error message saying “A device ID has been used that is out of range for your system”. The program opens but I can do nothing with it. On the offchance that someone reading this understands that, Question 3 would be, how do I fix this?
Link to device toolbar.
Thanks Steve
I can now follow the 6 steps marked in green. The settings are now as follows
However, I’m not much further ahead. If I have a You-tube video with sound playing, then press the record button, the sound trace recorded is dead flat, even though the sound through the speakers is normal.
From the “Help” menu, select “Audio device info”. Copy and paste the full audio device information into your reply. That may tell us what setting you need to change.
Default recording device number: -1
Default playback device number: 1
Device ID: 0
Device name: Microsoft Sound Mapper - Output
Host name: MME
Recording channels: 0
Playback channels: 2
Low Recording Latency: 0.090000
Low Playback Latency: 0.090000
High Recording Latency: 0.180000
High Playback Latency: 0.180000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 1
Device name: Speakers (Realtek High Definiti
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 2
Device name: Realtek Digital Output (Realtek
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 3
Device name: Primary Sound Driver
Host name: Windows DirectSound
Low Recording Latency: 0.000000
Low Playback Latency: 0.120000
High Recording Latency: 0.000000
High Playback Latency: 0.240000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 4
Device name: Speakers (Realtek High Definition Audio)
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 5
Device name: Realtek Digital Output (Realtek High Definition Audio)
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 6
Host name: Windows WASAPI
Low Playback Latency: 0.003000
High Playback Latency: 0.010000
Supported Rates:
    48000
Device ID: 7
Device name: Realtek Digital Output (Realtek High Definition Audio) (loopback)
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.003000
Low Playback Latency: 0.000000
High Recording Latency: 0.010000
High Playback Latency: 0.000000
Supported Rates:
Device ID: 8
Supported Rates:
    48000
Device ID: 9
Device name: Speakers (Realtek High Definition Audio) (loopback)
Supported Rates:
Selected recording device: 7 - Realtek Digital Output (Realtek High Definition Audio) (loopback)
Selected playback device: 8 - Speakers (Realtek High Definition Audio)
Supported Rates:
    48000
Recieved -9996 while opening devices
Thanks.
Your current device selection and its capabilities are shown at the bottom of that log:
Supported Rates:
    48000
Try setting the Default Sample Rate to 48000 (“Edit menu > Preferences > Quality”), then restart Audacity.
Default is already 48,000. (32 bit float)
The picture that you posted shows the sample rate as 44100 https://forum.audacityteam.org/t/how-to-record-streamed-sound-eg-from-you-tube-solved/43670/3
If you are not starting a new project when you record, you may need to reset the “Project Rate” (lower left corner of the Main Audacity window) to 48000.
Don’t understand the significance of the 44,100, but it looks like 48,000 this time …
It’s significant :wink:
To record with WASAPI loopback, the recording settings in Audacity must match the settings in the Windows Sound Control Panel.
The “Default Sample Rate” setting in Audacity Preferences is only the “default”. It can be overridden if either you manually changed the “Project Rate” (lower left corner of the main Audacity window), or if you import a file into an empty project. The “Project Rate” setting shows the actual sample rate that Audacity is using, and that is the sample rate that will appear when you create a new track.
There’s a couple more settings that may affect your ability to record:
Open Windows “Sound”, choose the main “Recording” tab then right-click over your chosen recording device and choose “Properties”. Click the “Advanced” tab, then put a checkmark (tick) in both Exclusive Mode boxes.
Choose the main “Playback” tab then right-click over your chosen playback device, choose “Properties,” click the “Advanced” tab and similarly enable both Exclusive Mode boxes.
See here for more details: http://wiki.audacityteam.org/index.php?title=Mixer_Toolbar_Issues#vistacp
By the way, the issue seems to be the same as in this topic https://forum.audacityteam.org/t/cannot-record-what-heard-from-system-website-streaming/34295/1 so I’m hoping that your issue is also just a matter of finding the right settings that suit your hardware.
If you want to record from the “Speakers (Realtek High Definition Audio)” playback device, then you must choose “Speakers (Realtek High Definition Audio) (loopback)” as the recording device, not loopback of the digital (HDMI) output.
Thanks Steve - I hope to look at this in the next day or two.
By the way, I just noticed that the bottom section of my last uploaded image was missing, so I’ve gone back to that post and attached an extra image of the bottom left window, showing the 48,000.
MAGIC - thank you!!! Changing that setting does the trick - :smiley: :smiley:
Forum contributors like you and the others who have taken the time and trouble to respond, can make a big difference in people’s lives. In this case your tip, along with Steve’s earlier one, have solved a problem that has been time-consuming and very frustrating for me for many weeks now. This means I should be able to do everything I want quickly using only two programs - Audacity and Amazing Slow Downer (three actually, as I should also include Music Publisher). [PS the test is from You-tube - Beethoven’s Pathetique starts dramatically at 6.5 seconds …]
