I have read innumerable posts on recording off the Web - not only via audacity but from “free” & “pay for” sound recording software
All those related to using Audacity - none took account of the fact that in addition to the sound device on the motherboard board, I have an additional sound card - SB extreme - (There are Many!!)
And … that “I dont have” access to “Stereo Mix” or whatever …
And… that I have multiple record & playback devices (seen Via Control Panel/Sound) …S/PDIF’s, Logitec Wireless Earphones/Mics , SB X Fi Xtreme, High Def Audio Devices, Speakers, Micrphones blah! blah! - Sheesh !!
I am not a big techie but I have a reasonable brain - but as I say none of the suggested ways worked for me (or I am just plain dumb … DOH!).
I had always thought that the most obvious way was to get the incoming sound (speaker) diverted to a line in which could be used for the recording device - but could not make sense of the various options shown in the Sound Device Window (ref Above)
So step 1… Link the speaker port (Green) with a cable 3.5mm both ends to input line (blue) on the mother board - see back of computer. Don’t confuse with added sound cards!!
Step 2 … disable (you can allways re-enable them) all devices relative to S/PDIF’s, Logitec Wireless Earphones/Mics , SB X Fi Xtreme (or what ever add on card you have) …
If all else fails, [u]Total Recorder[/u] ($18 USD & up) comes with it’s own virtual driver and it has a reputation of “just working”. (I don’t own Total Recorder).
First, select your device (SoundBlaster or Motherboard, etc.), then select the appropriate input (mic, line, etc.)
Win7 should have “Loopback”.
That should work if you select the line-in and the correct hardware device (your motherboard soundchip or your SoundBlaster).
If you want to hear what you’re recording you’ll also need a Y-Adapter (splitter) to connect both your speakers (or headphones) and line-in.
