Hi,
I’m using Debian Buster and Audacity 2.2.2 installed from the Debian repository.
I’m trying to figure out how to have Audacity record from the signal going to the speakers rather than the signal from microphone.
I found this FAQ, that basically says to set microphone to “pulse”. I have many options for the microphone device, but none is just pulse.
https://www.osradar.com/record-speaker-output-on-linux/
Any help on what I’m missing?
Thanks!
Mark
I’m a Windows guy, so…
Did you try the suggestions from the [u]Audacity Manual[/u] ? There are a couple of other suggestions besides PluseAudio.
Your Debian distribution may not have come with PulseAudio. (I assume it can be installed.)
August 6, 2020, 7:17pm
3
Debian uses PulseAudio by default. If Pulse is not available in Audacity then there’s something weird going on. Please post your “Audio Device Info” (see: https://manual.audacityteam.org/man/help_menu_diagnostics.html )
Thanks!
Here’s my Audio Device Info
Default recording device number: 20
Default playback device number: 20
Device ID: 0
Device name: HDA Intel PCH: ALC3266 Analog (hw:0,0)
Host name: ALSA
Recording channels: 2
Playback channels: 2
Low Recording Latency: 0.005805
Low Playback Latency: 0.005805
High Recording Latency: 0.034830
High Playback Latency: 0.034830
Supported Rates:
44100
48000
Device ID: 1
Device name: HDA Intel PCH: HDMI 0 (hw:0,3)
Host name: ALSA
Recording channels: 0
Playback channels: 8
Low Recording Latency: -1.000000
High Recording Latency: -1.000000
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 2
Device name: HDA Intel PCH: HDMI 1 (hw:0,7)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 3
Device name: HDA Intel PCH: HDMI 2 (hw:0,8)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 4
Device name: HDA Intel PCH: HDMI 3 (hw:0,9)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 5
Device name: HDA Intel PCH: HDMI 4 (hw:0,10)
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 6
Device name: C-Media USB Headphone Set: Audio (hw:1,0)
Host name: ALSA
Recording channels: 1
Low Recording Latency: 0.008685
Low Playback Latency: 0.008685
Supported Rates:
44100
48000
Device ID: 7
Device name: sysdefault
Host name: ALSA
Recording channels: 128
Playback channels: 128
Low Recording Latency: 0.021333
Low Playback Latency: 0.021333
High Recording Latency: 0.021333
High Playback Latency: 0.021333
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 8
Device name: front
Host name: ALSA
Supported Rates:
44100
48000
Device ID: 9
Device name: surround40
Host name: ALSA
Supported Rates:
44100
48000
Device ID: 10
Device name: surround51
Host name: ALSA
Supported Rates:
44100
48000
Device ID: 11
Device name: surround71
Host name: ALSA
Supported Rates:
44100
48000
Device ID: 12
Device name: hdmi
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 13
Device name: lavrate
Host name: ALSA
Low Recording Latency: 0.007755
Low Playback Latency: 0.007755
High Recording Latency: 0.023220
High Playback Latency: 0.023220
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 14
Device name: samplerate
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 15
Device name: speexrate
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 16
Device name: pulse
Host name: ALSA
Recording channels: 32
Playback channels: 32
High Recording Latency: 0.034807
High Playback Latency: 0.034807
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 17
Device name: upmix
Host name: ALSA
Recording channels: 8
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 18
Device name: vdownmix
Host name: ALSA
Recording channels: 6
Playback channels: 6
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 19
Device name: dmix
Host name: ALSA
Supported Rates:
48000
Device ID: 20
Device name: default
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Selected recording device: 16 - pulse
Selected playback device: 16 - pulse
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available recording sources:
0 - Headphone Mic:0
1 - Headset Mic:0
2 - Internal Mic:0
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - Headphone Mic:0
3 - Headphone Mic Boost:0
4 - Speaker:0
5 - PCM:0
6 - Headset Mic:0
7 - Headset Mic Boost:0
8 - Internal Mic Boost:0
Recording volume is native
Playback volume is native
August 7, 2020, 8:56am
5
According to that, you have “Pulse” selected:
As DVDdoug wrote, these instructions are what you need: https://manual.audacityteam.org/man/tutorial_recording_computer_playback_on_linux.html
Thanks for the help!
I shut down Virtualbox which simplified the audio devices.
Default recording device number: 7
Default playback device number: 7
Device ID: 0
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 1
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 2
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 3
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 4
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 5
Device name: hdmi
Host name: ALSA
Supported Rates:
32000
44100
48000
88200
96000
176400
192000
Device ID: 6
Device name: pulse
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 7
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Selected recording device: 7 - default
Selected playback device: 6 - pulse
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
0 - Headphone Mic:0
1 - Headset Mic:0
2 - Internal Mic:0
0 - Master:0
1 - Headphone:0
2 - Headphone Mic:0
4 - Speaker:0
5 - PCM:0
6 - Headset Mic:0
I’m getting stuck on step 2. I’m supposed to set the Microphone to Pulse or default, but those aren’t in the list. Here’s what it looks like:
August 7, 2020, 3:54pm
7
The names in the Device Toolbar look a bit strange and unhelpful, so you will need to experiment. What you are aiming for is for the Audio Device Info to say that both the “Default recording device number” and “Default playback device number” correspond to “Device name: pulse”. The numbers will change depending on what devices (real and virtual) are present.
In you most recent post, the “Device name: pulse” is “Device ID: 6”
Once that is set, you should be able to use PulseAudio Volume Control as described in the manual.
Hi Steve,
Sorry to be dense.
Is this something I’m doing in Audacity or somewhere else? If so, where?
August 8, 2020, 4:22pm
9
The exact details of what appears in the Device Toolbar depends on what devices are present, the operating system, and the device drivers. This is what the recording device selection looks like on my (Xubuntu) computer:
