How to recall screen to input details of mp3 after finishing editing mp3 file and doing export
Hello
Japanese Windows 10 Home, version 21H1, OS build 19043.1645, 64 bit, 16gb memory
Audacity 3.1.3
I was using Audacity 2.4.3 because of problem of freeze using Japanese input method editor.
Since solution to this was found, I am using 3.1.3.
Problem:
when I am finished editing mp3 file, click export, the next screen allows u to name a file. However after naming the file, it is immediately saved without showing another screen to fill in the details such as artist name, genre, etc.
Is there a button somewhere in preferences that wud display another screen where i can input details such as artist name, genre, date, etc?
Without this, I have to again edit the file I just created to enter details by right clicking the file, choosing properties etc.
Edit → Preferences → Import/Export → Show Metadata Tags Editor before Export,
Note that Audacity doesn’t support embedded artwork.
I frequently use [u]MP3Tag[/u] (in English). It’s from Germany and it does apparently support Japanese language.
Hello DVDdoug
Yes, that is exactly what I was after, thank u so much
snoma01
