How to load label track using nyquist
Hi. I am able to read the label track in audacity using the code below but not able to create an empty track and load these values. Please help.
;nyquist plug-in
;version 4
;type process
;name "Load Labels"
;action "Load Labels"
; Define the label file path with spaces
(setq label-file "C:/Users/audio_master/T_6006.txt")
; Open the label file for reading
(setq input-port (open label-file "r"))
; Read and process each line of the label file
(loop
  (setq line (read-line input-port))
  (if (null line) (return))
  (format t "~a~%" line))
; Close the label file
(close input-port)
;nyquist plug-in
;version 4
;type generate
;name "Load Labels"
;control LABEL-FILE "Label File" string "" "C:/Users/audio_master/T_6006.txt"
(defun import-labels (fname)
  (let ((file-pointer (open fname "r"))
        labels)
    (do ((line (read-line file-pointer) (read-line file-pointer)))
        ((not line))
      ; Convert string to a list
      (setf label (eval-string (format nil "'(~a)" line)))
      ; Set third element to an empty string.
      (setf (nth 2 label) "")
      (push label labels))
    (close file-pointer)
    labels))
(import-labels LABEL-FILE)
