I make mix cds on iTunes. I took a spoken word sound bite off a song and want to add it to the beginning of another song. Even though I cleanly edited the sound bite in Audacity, whenever I make a CD (with no pause between tracks selected) I get a second of pause. Is there a way in Audacity to merge two tracks together end to end to make one track? I haven’t been able to find the answer in the FAQ’s. Thanks.
Open spoken word sound bite in Audacity.
Go to edit - select - all
Go to edit - copy
Close sound bite and open track you want to add it too in Audacity
Go to edit - paste
sound bite should now be at beginning of track
Then export whole track to whatever format you use
Awesome! That worked great! Thanks!
