the recording outcomes from my computer sound card isn’t as good or as loud as the audio source that I’m recording from.
theres a big difference between the sound of the audio im recording from and the recorded outcome.
are there some settings that would help fix this problem?
my computer is window 7
It would help if you told us what sound card you have and what your audio source is and how you connect it to your sound card…
