How to get or change Audacity themes?
How to change internal themes colors like other software?
Current internal there are not enough.
Why there is no ability for that, yet?
I found a website for some themes, but they are not compatible with new releases.
Is there any other way?
Possibly. But you would have to do the development work yourself.
Currently the Audacity developers are moving away from the current ImageCache system. For additional information see: Support multiple custom themes · Issue #4248 · audacity/audacity · GitHub
