How to edit the volume of a waveform section? [SOLVED]
Hi guys,
I’m going to skip the version detail as I assume it’s not necessary… I just wanted to ask, to anyone kind enough to answer, if there’s a way to edit the volume of a only a SECTION of a particular track, rather than the whole track? I know you can always go ahead and create a new track, but since I’d like to adjust the volume in quite a few areas, it would be helpful to know if this could in some way be done all in the same track.
Thanks very much in advance,
Zak
We don’t ask you that for a joke. :wink:
Features can change from version to version. Different versions of Mac may required different versions of Audacity - that will be true if we drop support for OS X 10.4 and 10.5 as I expect we will do soon.
Have you tried Envelope Tool ?
Thank you, this answered my question perfectly! And I’ll be sure to supply that info next time.
Cheers.
