Does the program have the ability to simultaneously listen to already recorded tracks and at the same time play a new track from the instrument, synchronously, in order to build up your composition with tracks?
How to do something like montage from difference, synchronized "by hands " , by own hearing tracks ?
Yes … https ://manual.audacityteam.org/man/tutorial_multi_track_overdubbing.html
Some tweaking is required to get everything in-sync … https ://manual.audacityteam.org/man/latency_test.html
(each computer set-up will have different latency,
once you have measured latency on your machine, and dialled-in compensation, that’s it: set & forget).
OO m good , thank, very thank, i begin read your bookmarks
